Truecrypt
25 Nov 2007
London
The question is, how secure is it.. im using the AES-Twofish-Serpent on a 4GB USB...
who would be able to crack that, im assuming it would take too long with a supercomputer? so is there a work around, either way if its able to be cracked i need a software which cannot.
Apparently its very secure. Not totally unhackable, but supposedly the time required to hack it is longer that the universe has left...
It would theoretically take more time than the universe has already existed to break using modern technology, thats not to say that someone wont find a way to crack it somewhere down the line but its pretty secure.
With current technology, it's impossible to crack - would probably take thousands of years if you use a decent password. The encryption schemes have no back doors - plus, even if one of them had a vulnerability, your data would still be safe as it's encrypted with three different cascading encryption schemes.
You've got far more to worry about with regard to someone installing a keylogger on your machine. Nobody's gonna try and crack the encryption, which is practically impossible, when they could just get the password as you type it in.
You may also want to use nested partitions so you have plausible deniability. In case of a ripa request, or someone else trying to force you to reveal the key.
whats a ripa request?
im not worried about being forced, thats not as easy as it sounds
your sneakiness impresses me
Need to keep all those downloaded souls safe eh?:p
:d mainly bank details including passwords and of course some other sensitive information.
The Regulation of Investigatory Powers Act 2000 makes it an offence to fail to provide encryption keys to the police when requested, by using nested partitions you can hand over a encryption code which will reveal sensitive looking information, and keep the real information in another undetectable partition hidden inside the main one. Truecrypt files also appear to be random data so it's impossible to prove there is encrypted data in the first place. Makes for a good defence against the police state this country is turning into!
It depends on the mode of encryption. Some systems use(used) 7 round AES which is secure, but CAN be broken within a reasonable time frame. Even using the standard 10 round AES it is possible to crack by noticing patterns in the encrypted data, the most secure method is 'feedback' mode, where the encrypted data is fed back into the encryptor as the key for the next block of data.
http://en.wikipedia.org/wiki/Block_cipher_mode
Provided you keep your private keys on a separate media, you'll be as safe as you could be on todays pcs. I would further recommend setting the swapfile to scrubbed on shutdown (its a group policy/registry edit) as windows has the notion of swapping decrypted information and you could leave perecious private info on there ;)
It uses XTS with 14 round AES which is the most secure practical method. Ofc you can always encrypt a one time pad file making it impossible to brute force.
