Gigabyte GA-EX38-DS5
13 Apr 2008
Notts / Reading
I was thinking of ordering one of these. Ive done a search on here and very little came up, and google didnt say much either.
Ive just come off a 680i mobo as im normally a nvidia fan, but im moving onto 4850's and intel chips as i fancy a change.
anyone care to shed some light on it? / what should i expect?
I had an X38-DS4 which is identical, just with a different heatsink....rather solid board, good features, pretty good overclocker. BIOS is a little confusing though.
Running one in my system at the moment, running at 8600 @ 4.4ghz with a GTX 8800 so far been quite impressed, only thing I dislike I had trouble controling my fans which the my old board (Abit IP35 Pro) done quite well.
I was tempted to buy one of the B grade boards.
i was pretty impressed with 8usb's on the back.
sounds like you recommend it then reflux? its £85 in the B grade.
Yeah, go for it, although obviously be aware that it's b-grade so the warranty might be non-existent and you might get f'all in the box/no box at all :)
I think it's end of line - as there is no B grade in the description - not sure if that means anything :o
can anybody clarify this point?
i did notice these about a week ago, I think there were 9 or 10 units - now just 4
are these end of line, but new products?
it looks like its on offer/clearance, definitelly not bgrade
well, i found it under B grade. I hope its clearance...... extras :eek:
thanks all for the help. Its ordered and should be at home....when i get home. :)
ill post what i think when every things running, assuming there's some left.
Yeah that's one thing I miss about my 680i board. With it you could control each 3 pin fan header individually, With the Gigabyte X38/X48 you only have the option of controlling the fans with 2 options which are Voltage or PWM. The option applies to all headers so you can't have one fan running 12v and the other running 5v
