Final Fantasy games on pc
24 Oct 2005
North East
Which ones are for pc and which would be easiest to get into cos of the videos i see at utube it seems awfully complicated with stats and weapons and spells, like hundreds to remember and use. Where im the type that would just use whatever's most powerfull lol. Also one that has AA if possible cos i seen some vids and there really low res gfx and jaggies aplenty which i hope to avoid if trying to play one of these.
Mainly interested cos i really used to like zelda a link to the past on snes and figured it might be the same.
FFVII and FFVIII are the only ones on the PC. Both are amazing imo, two of my favorite games.
FFXI is on PC too but its totally different, its an MMORPG.
i think the best option would be to buy the playstation versions and play them on a emulator, you can run them at high resolutions with aa & af that way
it takes a bit of tweaking but you can get the games looking really good
I think theres a high res patch for ffvII isnt there, does that not help? And can u not force aa and af on with pc versions?
Yeah, there's a hi-res patch but you try to find anywhere that sells FFVII for the PC. That's like trying to find rocking horse ****.
They really should have released FFX for the PC.
Hope the rumours about FFXIII come to fruition!
TBH I think it actually looks worse in high res. At least the older blocky graphics kind of masked the fact that every character model is made up of about 3 polygons...
