With an exif extractor
Google for "exif reader". I use firefox so I use a firefox plugin. Also I have DPP and Lightroom - they both read Exif. There are plenty of other tools.
Your picture has a strong orange cast, because it was shot under domestic lighting. I would encourage you to correct for this. I'm not particularly good at fiddling with the levels and I only had your JPG (not the RAW) to play with, but in Lightroom, I set the colour to "auto", decreased the brightness and increased the contrast to get this:
Which brings her skin to a slightly more believable tone.
Have a play. When you get the hang of it, you'll find that you want to adjust the tones in every picture...
And finaly, here is the info from your Exif:
Exif IFD0
* Camera Make = NIKON CORPORATION
* Camera Model = NIKON D300
* Picture Orientation = normal (1)
* X-Resolution = 3000000/10000 = 300
* Y-Resolution = 3000000/10000 = 300
* X/Y-Resolution Unit = inch (2)
* Software/Firmware Version = Adobe Photoshop CS3 Windows
* Last Modified Date/Time = 2008:12:08 20:25:29
* Artist =
* Y/Cb/Cr Positioning (Subsampling) = co-sited / datum point (2)
* Copyright Owner =
Exif Sub IFD
* Exposure Time (1 / Shutter Speed) = 10/150 second = 1/15 second = 0.06667 second
* Lens F-Number/F-Stop = 18/10 = F1.8
* Exposure Program = manual control (1)
* Exif Version = 0221
* Original Date/Time = 2008:12:08 21:16:02
* Digitization Date/Time = 2008:12:08 21:16:02
* Components Configuration = 0x01,0x02,0x03,0x00 / YCbCr
* Compressed Bits per Pixel = 4/1 = 4
* Exposure Bias (EV) = 0/6 = 0
* Max Aperture Value (APEX) = 16/10 = 1.6
Max Aperture = F1.74
* Metering Mode = center weighted average (2)
* Light Source / White Balance = unknown (0)
* Flash = Flash fired, compulsory flash mode, return light detected
* Focal Length = 500/10 mm = 50 mm
* User Comment (Hex) = 0x41,0x53,0x43,0x49,0x49,0x00,0x00,0x00,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20
User Comment Character Code = ASCII
User Comment =
* Last Modified Subsecond Time = 08
* Original Subsecond Time = 08
* Digitized Subsecond Time = 08
* FlashPix Version = 0100
* Colour Space = sRGB (1)
* Image Width = 1000 pixels
* Image Height = 899 pixels
* Image Sensing Method = one-chip color area sensor (2)
* Image Source = digital still camera (DSC)
* Scene Type = directly photographed image
* Colour Filter Array (CFA) Geometric Pattern = 0x00,0x02,0x00,0x02,0x00,0x01,0x01,0x02
* Custom Rendered = normal process (0)
* Exposure Mode = manual exposure (1)
* White Balance = auto (0)
* Digital Zoom Ratio = 1/1 = 1
* Focal Length in 35mm Film = 75
* Scene Capture Type = standard (0)
* Gain Control = n/a (0)
* Contrast = normal (0)
* Saturation = normal (0)
* Sharpness = normal (0)
* Subject Distance Range = unknown (0)
Andrew
