RUF CTR3
18 Oct 2002
Nordschleife
RUF CTR3: OFFICIAL DETAILS AND SPEC
All new supercar from Ruf
Nearly 700bhp for CTR3You're looking at what should be one of the quickest and most effective performance cars of 2007. This is the Ruf CTR3, the latest creation from the Pfaffenhausen-based Porsche legend.
Details of the new car have been leaking out onto the web over the last 48 hours, and much to Ruf's concern, the assumption has been that the CTR3 is Cayman based. In fact, only the rear lights are shared with Porsche's mid-engined production coupe, the rest is altogether more exotic.
We're aware that some of you may have seen the images and details already, but for the benefit of those that haven't we've posted them here. We're also posting the official full specifications and the word on the cars construction gathered from speaking to the Ruf team.
Only rear lights from CaymanThe starting point for a CTR3 is the front crash structure and floor pan of a 997, delivered straight from Porsche. Using this allows Ruf to take advantage of Porsche's enormous investment in safety and chassis technology in line with their large unit production numbers. A roll cage structure joins with the A pillars and sills for strength and stiffness, with a cradle attached behind the occupant cell to hold the engine and the transversely mounted gearbox. Ruf take the aluminium doors (with side-impact protection) and bonnet from the 997 Turbo and GT3 models, while the rest of the body panels - unique to Ruf - are made from a carbon-composite material.
six speed sequential gearboxThe CTR3 uses one of Ruf's full house flat sixes. With a capacity of 3,746, two KKK turbo chargers and two air/air intercoolers, it produces 690bhp. The gearbox has been developed by Ruf with a 'leading industry supplier' and is a fully sequential six-speed unit operated by a central gearlever. It should have no trouble in coping with the CTR3's 657lb ft of torque as it's apparently safe up to nearly 900lb ft of twist.
The first cars will be ready for test later this summer. For the full details, read on below...
Engine
Type turbocharged boxer
Cylinders 6
Displacement 3,746 cc / 228.6 in3
Bore 102 mm / 4.01 in
Stroke 76.4 mm / 3.01 in
Output 515 kW (700 hp) at 7,000 rpm
Max. torque 890 Nm / 656.5 lb-ft
Compression ratio 9.2 : 1
Engine control unit Bosch Motronic with OBD-2
Turbo charger two KKK turbo chargers
Intercooler two air-air-intercoolers
Transmission
Power delivery rear wheel drive
Transmission sequential 6-speed-manual transmission,
transversal, angle drive, shift indicator in the instrument panel
Limited slip differential multi-disc locking differential
Locking value load / deceleration 40 % / 60 %
Chassis
Front axle McPherson struts, anti-roll bar
Rear axle multilink rear axle, anti-roll bar
horizontal coil over shock absorbers
Steering Power assisted rack and pinion
Brakes
Brake callipers front/rear 6 piston fixed light alloy callipers
Brake discs front/rear ventilated and cross drilled
ceramic composite discs
Brake disc diameter front/rear 380 mm / 15 in / 380 mm / 15 in
Anti-lock braking system Bosch ABS 8.0
Wheels and tyres
Wheels front/rear 8.5" x 19 / 12.5" x 20
Tyres front/ rear 255/35 ZR 19 / 335/30 ZR 20
Size and weights
Length 4,445 mm / 175.0 in
Width 1,944 mm / 76.5 in
Height 1,200 mm / 47.2 in
Wheelbase 2,625 mm / 103.3 in
Front track 1,506 mm / 59.3 in
Rear track 1,585 mm / 62.4 in
Empty weight with 6 speed manual transmission
According to DIN 1,400 kg / 3,086.4 lbs
According to EG-standards 1,475 kg / 3,251.8 lbs
Performance
Top speed 375 kph / 235 mph
0-100 kph / 0 - 62 mph 3.2 sec
Price
Euro 380,000.00 (plus VAT)
http://www.pistonheads.com/news/default.asp?storyId=16159
Some time next year I'll be filming a customer taking delivery of his car (RUF Factory in Germany) then later in the year hope to be filming him take it around the Nurburgring!
Looks are hit and miss but by god its quick! Can't wait! :D :cool:
Love it. Hope they get one on the Top Gear track.
Also love your RUF video in link.
Shame it's a lifetime's worth of wages though :(
It'll be bobbins and if we see no bread then it never happened. Anyone can Photoslop a video these days!
Ok it will be ace but don't tell anyone
I'm sure I saw this at Goodwood Festival of Speed?
Will go check photos......
Yep I did, it was last year.
http://www.putfile.com/pic/5781280
