PLEASE HELP ME TO O/C E8500 on P5Q-E from 3.8GHZ to 4GHZ + make system stable
13 Nov 2008
Hi, i currently have 3.8 ghz with E8500
want to raise to 4GHZ 24/7 ... will it be safe?
here is my BIOS:
AI Overclock tuner: Manual
CPU Ratio Setting:9.5
FSB Strap to North Bridge:400
FSB Frequency:400
PCI-E Frequency:100
DRAM Frequency: DDR2 - 800Mhz
DRAM CLK Skew on Channel A1:AUTO
DRAM CLK Skew on Channel A2: Same as above
DRAM CLK Skew on Channel B1: Same as above
DRAM CLK Skew on Channel B2: Same as above
DRAM Timing Control:MANUAL
1st Information :
CAS# Latency:4
DRAM RAS# to CAS# Delay:4
DRAM RAS# Precharge:4
DRAM RAS# Activate to Precharge:15
RAS# to RAS# Delay :AUTO
Row Refresh Cycle Time:AUTO
Write Recovery Time:AUTO
Read to Precharge Time:AUTO
2nd Information :
READ to WRITE Delay (S/D):AUTO
Write to Read Delay (S):AUTO
WRITE to READ Delay (D):AUTO
READ to READ Delay (S):AUTO
READ to READ Delay (D):AUTO
WRITE to WRITE Delay (S):AUTO
WRITE to WRITE Delay (D):AUTO
3rd Information :
WRITE to PRE Delay:AUTO
READ to PRE Delay:AUTO
PRE to PRE Delay:AUTO
ALL PRE to ACT Delay:AUTO
ALL PRE to REF Delay:AUTO
DRAM Static Read Control: Disabled
DRAM Read Training: Disabled
MEM. OC Charger: Disabled
AI Clock Twister:Moderate
AI Transaction Booster:AUTO
CPU Voltage:1.28
CPU GTL Voltage Reference (0/2):AUTO
CPU GTL Voltage Reference (1/3):AUTO
CPU PLL Voltage:AUTO
FSB Termination Voltage:AUTO
DRAM Voltage:2.1
NB Voltage:AUTO
NB GTL Reference:Auto
SBridge Voltage:AUTO
PCIE SATA Voltage:AUTO
Load Line Calibration:Enabled
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
CPU Clock Skew :Normal
NB Clock Skew :Normal
Advance CPU Settings
CPU VID: Disabled
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
Intel® Virtualization Tech: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
maybe someone can tell what can i change? volts + etc. for make system more stable and how can i reach 4ghz,
thank you
Looks to me like your mem might be getting maxed.... cas4 at 800 might be ok for your ram, but higher might be a struggle... try going to cas 5
I would like to help but its a diff Mobo and CPU.
I'm 24/7 stable (Orthos with CPU fan @ 0 RPM so passive) @ 10x400=4GHZ or 8x500=4GHZ @ 1.056v.
Memory would normally be 4:4:4:12 or 5:5:5:15 (some types are 18) regardless I would set the FSB Strap to North Bridge 333.
List your hardware in SIG please.
Assuming your ram does 850mhz ....also is your E8500 an e0 stepping? It will say in CPU-Z
FSB Strap to North Bridge:425
FSB Frequency:400
PCI-E Frequency:101
DRAM Frequency: DDR2 - 850Mhz
1st Information :
CAS# Latency:4
2nd Information :
3rd Information :
CPU Voltage:1.325
CPU GTL Voltage Reference (0/2):.63
CPU GTL Voltage Reference (1/3):.63
CPU PLL Voltage:1.52
FSB Termination Voltage:1.22
DRAM Voltage:2.1
NB Voltage:1.22
NB GTL Reference:.63
CPU VID: Disabled
Hi,thank you for posts guys!
my CPU iz revision C0 stepping 6!
GURUSAN: do you think your setting will be ok?
Thank you
That's the old Stepping and many E8400's cannot even reach 4GHZ.
Hmm I said about "FSB Strap to North Bridge" above well since it can only be set to 266/333/400 and gurusan has put in 425, I am now not sure I have thought of correct setting and I cannot reboot to bios right now to check as downloading stuff.
That's the old Stepping and many cannot even reach 4GHZ.
woops......fixed below
Thank you
If you have a C0 revision I suggest starting at 1.4V and monitoring temps. If its stable then knock down voltage.
FSB Strap to North Bridge:AUTO
FSB Frequency:425
PCI-E Frequency:101
1st Information :
CAS# Latency:4
2nd Information :
3rd Information :
CPU Voltage:1.325
DRAM Voltage:2.1
NB Voltage:1.22
CPU VID: Disabled
I'd doubt you'd have any trouble reaching 4ghz with the cpu tbh... I've a C0 and it can hit 4.5 without too much diff
Again many E8400 C0's cannot reach 4GHZ, the fact he has a lower Multi means the CPU/MOBO/Memory all need to reach a higher FSB.
I have corrected my above post as I misread and thought the OP had an E8400 C0 :o
I had major issue a few bioses ago setting the DDR speed to what I actually wanted from drop down box when I wanted 1000mhz (was fine at 800mhz).
I found out Auto (same speed) worked and I ain't sure if issue is fixed but I see no reason to not simply leave it Auto as the Memory will follow the FSB in 1:1 at Auto.
well, if i set RAM auto, will it work?
thanks
Yes if you want 1:1, I simply crashed at 500FSB(2000QP) choosing 1000mhz for the Memory.
If I set to Memory Auto it was same speeds but does not crash and can Orthos all day long.
Again this may be fixed for me in newer Bioses but I see no point in even changing from Auto.
