all 1000 achievment points on 360, does this have trophies for ps3?
Yus, the targets are the same as on the 360 too.
Is Mirrors Edge region free on the 360 does anyone know?
Its a great game m8 but surely its worth getting a local box at the price they are now aint it?
Should have waited!
£19.99 on both formats online now!
Ah, well that's placated me a bit, if the rest of them are less frustrating than Jack knife, then I'll certainly persevere.
i utterly loved this game, it was such a surprise to how to see how good it was and very refreshing to see a challenging game.
i found the speedruns much easier than time trials partly because you know some sections through time trials and because you dont have to do anything as high risk as you do in time trials... you just need to keep up a fairly decent pace.
search for the speedruns on youtube (the ones by user watuhboy were the most helpful for me) you dont have to follow the exact route but hes generally pretty fast.
jack knife is considered the hardest speedrun since its long and even on a good run it will be fairly tight... just memorise the route so you dont waste time stalling. you dont need to shoot anyone at any point and theres an exploit you can use on this level - just before you enter the sewers when you press the button and you have to wait for the door to open. you can pause the game and wait ~30 seconds then when you resume the door will open immediately, will save you around 15 seconds
thanks mate and good luck. the rest are much easier than jack knife, the only other one that is tricky is the last one but thankfully that is pretty short.
