ok where are the best guides to read ,where did you read fromThe best way to learn how to overclock is to read some guides and try it yourself, not as some guys on the internet to do it for you
hey guys i only want some top advice no need to war over it.Pilky01 are you on a mission to scare off as many newbies as possible or something?
This is the second time in a few days that you've been very curt with a new member, and both times the only advice you've eventually offered is to search or use Google.
This isn't GD. These are the support forums of a national retailer. If you can't answer the query then leave it for someone else to have a try at. Telling them to use the search function or - worse still - run to Google isn't really on tbh.
thanx will give it agoIf you get to a situation where a certain FSB runs fine under full load for hours, and adding 1MHz to it makes the machine fail to boot, then it's something more than just the CPU hitting it's limit. Could be an FSB hole (a range of FSB values that the onboard clock sucks at), for example.
As for keeping the memory in a valid range, let's take the example of my 5600+ based machine.
The main clock is 200 MHz, the RAM runs off that on a multiplyer of 4x giving 800MHz, the CPU runs on a multiplier of 14x giving 2.8GHz.
If you add 20MHz to that, you get a CPU at 3.08GHz and RAM at 880MHZ. BUT you may find the machine falls over. You then try changing the RAM to a multi of 3x (BIOS permitting of course), making the RAM run at 660MHz. You can then start upping the clock speed again until the machine falls over again, which, if the RAM is still at less than 800MHz, is almost certainly your CPU giving up (you can now think about voltages). If the right "balance" on your system happens to leave your memory underclocked a little (for example 700MHz) you can usually get something back from it by tightening it's timings a bit.
AMD overclocking is a black art though. Most people here are Intel fanboys (largely for good reason....I prefer AMD myself, but for my gaming rig I went Intel because you just cannot ignore the silly overclocks you can get from something like a Q6600.....Your AMD will not clock as far, but it will run nicer clock for clock, and the machine will respond quicker for some reason), and know the Intel way of overclocking. You might get better advice on this matter from a dedicated AMD overclocking forum.
only used small amount of paste followed fitting inst to the letteri wouldnt use 3dmark as a stress test, for a quick test use OCCT set it to CPU only and give it 30min blast.
your temps look a bit iffy, 52 idle and 54 underload dosnt sound right what are you using to measure the temp, a good program to use is HWmonitor this will give you most of your system temps including GFX and HD.
Im sorry i cant be more specific about what settings to use as i have never used an AMD chip or mobo chipset.
Just take it nice and slow and good luck
edit just noticed newer post ...your temps have gone up 10C with the new cooler??? you haven't fitted it right r have used to much therml paste...check before you continue.
i know its still running at 3.53ghz and the temps are at 39c and stable ive done 3 occt cpu tests at 30 min bursts and all results show all stable.That's a hell of a difference in temps .
