Driving back from Bolton on saturday, im watching the temperature gauges. Oil is much cooler than usual, around 50c, and water temperature wasnt registering. Odd. So i turned the heaters off and let the engine have some heat back, oil temp begins to climb, water temp starts to register, hits around 70 and then drops off again. How very odd. Hit a slight hill on the motorway and then it starts loosing power, as my speed and revs are dropping, water temp is climbing. GREAT. i know what that means.. engine off and abrupt stop on the hard shoulder, heaters on, rad fan override on, pop the bonnet, but before i get out i see the temp still rising, it peaked arond 120c and then sat there.
Looked under the bonnet and there is waterhose off. Had the car not lost power i'd happily convince myself that it was just a pipe coming off leading to a slight overheat, but it didnt play out that way. I walked to the services i'd just past, bought 4.5l of Buxton Spring water and walked back to the car. It had cooled down by now. Filled her. Reattached the hose. Left the expansion cap off and fired her up! ROUGH AS... with bubbles and exhaust fumes coming out the expansion tank.
RAC came and picked me and the car up, and after a brief look at the water feature that was now present in the expansion tank he didn't even try and fix it.
hmm this doesnt look right..
nope.. def a small leak going on there!!
fire ring isn't damaged though, its as if the head wasn't torqued down enough and its just squeezed out over the top of the gasket.
