hey all,
I'm currently trying to save the world by healing it using my newest best friend (the Princess!), however I'm now stuck and I'm wondering if anyone here can help!
Basically, I opened up the first 4 bits on the world map ok. I then collected enough light seeds to be able to use the temple and then traveled back to it.
Once at the temple I had a choice of which part of the world I wanted to go to next, indicated by 4 colored circles on the ground. I choose the green one (on the far left). Opened it up, set my location and started traveling off in that direction.
I'm now stuck within sight of the healing tree (my destination) on a flat square platform with small ledges sticking out of it. There are 3 other square platforms but I'm unable to reach any of them.
There is also a turning handle in the middle of the platform I'm on but I can't do anything with it.
Has anyone got to this bit, and can you help me???
Does anything I've written make sense???
(I'll try and get a screen shot of the area i'm on in a minute to help)
Cheers in advance.
Cheers in advance.
