What do people think of ZoneAlarm compared to other AV
15 Dec 2008
What do you guys think of zonealarm i have been using it for a while and find it works well for me, but i did wonder if there were any other AV/Firewall suites that were better in some way as i do find zonealarm seems to slow my system down some when running, not having much experience with other AV software other than AVG Free and Norton a long while ago.
Just wondered if there was something that worked better or was a bit less of system hog, what would you guys recommend to try out.
For free, you cant really beat AntiVir or Avast!
For paid, i guess the normal; Nod32 and Kaspersky
If you really need a firewall then I would recommend Commodo Firewall. Install and just disable the 'defense'.
With AV I would say Antivir. I installed it on a clients laptop the other day after finding a stream of trojans and it found and deleted every one of them.
All free and very good imo.
I dumped ZA a few years ago after getting annoyed with it. Install ZA and everything would be fine but then after a few weeks it would delay the start of my desktop, de-install and re-install with clean settings would always fix it again but I got sick of doing this.
ZA is a virus
more often than not, a ZA user is also a wielder of this..
