so you have to get under the car anyway? seems even more pointless now
For the CTR, you really need to take a wheel off to get to the filter properly so this would be pretty pointless. I expect it's got limited applications for most cars.
I'd also be worried about the lifetime of the sump plug and washer as they're designed to be replaced yearly I would assume. Probably not an issue but if the car has it's oil pumped all its lifetime is there a chance they'll deteriorate?
Indeed, possibly heard it from meTis what both my local merc specialist and 2 different main dealers have always done.
I heard somewhere this is what Mercedes do on some/all their cars. Could have been idle gossip tho![]()
I use a pela...or pela style...£30 from screwfix.
Perhaps on your engine..my merc filters are accessed through a lid on the top of the engine, you unscrew that and pull the filter out by its handle. Pop a new one in and job done. Agreed its pointless on an engine where the filter is under the car.
I'm suprised you're not provided with a butler who does it all for you on your driveway![]()
The cars get serviced at the main dealers, i was just saying how the layout is on them which makes these devices very handy should you want to change the oil yourself.
