Hello,
I used to have spec in sig but I got a Q9550 from my dad.
I update bios all goes fine etc pc boots once to windows and I turn it off to swap the cpu.
E6420 goes out, Q9550 goes in.
Pc doesn't boot whatever I do.
So I try it with 1 ram stick, it boots, I do all the standard things like turn on my sata controller into raid mode, raise the northbridge volts a notch to 1.45 ( gave the pci-ex 1x bug with stock volts and iirc it also wouldn't boot with 4x1 gb before if not done this) , set ram @ 2.1v and config spd timings, save reboot, it's all fine.
I turn off pc to re-add the 3 other sticks, no luck.
Tryed some more things but this is the conclusion:
Pc will not boot with 4x1gb, be it at proper speed or ram underclocked, with the Q9550.
Pc will boot with 3x1 gb, underclocked and at proper speed with the q9550.
Pc will boot with the E6420 and 4x1gb.
I really want that 1 extra gb, alt tabbing out of gta iv is dead slow with just 3gb and shutting down memory intensive games takes ages ( till the desktop is usable again...
Any ideas to get 4gb of ram working again? Is it safe to raise the nb volts another notch, to the 2nd to highest value ? Can the stock cooling handle this? Won't I burn my board ? Would more ram volts help, on my previous board, p5ld2, i used to run my ram @ 2.3 volts, on this board it never booted with 2.3 volts though but it used to work fine on 2.1 before I got the q9550.
