keeping speedstep enabled when clocking doesn't do anything anyway....the vcore does not drop....therefore it's very ineffective anyway.
I have toyed with the idea of speedstep but never actually used it, does the lower clockspeed use less juice or is it the same regardless of clockspeed at any given voltage?
	Not true, you still save power as the vcore does drop. Watch CPU-Z when switcing between idle and load and you'll see it rise and fall. Even my Q6600 does this!
So you're setting the vcore to auto while overclocking instead of the lowest stable vcore then. I doubt you really need 1.34v for 2.3GHz.
Heh. It was really only around 4 pages on whether or not he should change to a Quad. The rest was much worse.I can't believe we have 10 pages on the subject of wether FOX should buy a Quad core.
Its so outdated boring and dull it doesn't warrant such enthusiasm.
Yeah if you read it all Easy you could see it was a reasonable debate until after page 4 then it all got a bit silly.
There are better cpu's out now and Q9450's are going for 140-160.
45nm ,more cache,cooler, faster clock for clock and new instruction sets.
