18 Dec 2008 at 10:28 #1 Niir Niir Associate Joined 3 Nov 2008 Posts 351 ive got a sapphire 4870 512mb so will i have any issues running a 20'' monitor and a 24'' monitor together? what software would you guys recomend?
18 Dec 2008 at 10:47 #2 Talon Talon Associate Joined 2 Jun 2005 Posts 1,496 Location Hull I have a 20" and 24" running off a 4870X2 on Vista64 with no problems at all. I use Ultramon for the nice little tweaks it give ya.
18 Dec 2008 at 10:47 #3 Snakedoctor Snakedoctor Soldato Joined 13 Sep 2007 Posts 3,951 If running Vista 64 and Aero, you may get the odd display driver has recovered type error.
18 Dec 2008 at 12:38 #4 Niir Niir Associate OP Joined 3 Nov 2008 Posts 351 where can i see whether aero is disabled/enabled? and also what does it do? im fairly sure its not turned on atm.
18 Dec 2008 at 13:09 #5 Snakedoctor Snakedoctor Soldato Joined 13 Sep 2007 Posts 3,951 Niir said: where can i see whether aero is disabled/enabled? and also what does it do? im fairly sure its not turned on atm. Click to expand... It's the see through theme of Vista. Set your theme to basic.
18 Dec 2008 at 23:20 #6 Niir Niir Associate OP Joined 3 Nov 2008 Posts 351 ah didnt have it enabled, so is it as simple as installing the software and plugging the second monitor into the other port on my gfx card?
19 Dec 2008 at 10:49 #7 Shash Shash Associate Joined 7 Nov 2007 Posts 492 I used to run different sized monitors in dual display, never gave me trouble
19 Dec 2008 at 11:00 #8 Strife212 Strife212 Soldato Joined 15 Dec 2007 Posts 16,567 Yeah as others have said it's fine, I got 22" 24" and 37" hooked up
