I run 5 12cm fans in my PC.
I replaced weak ones with stronger ones. Currently I'm using Xinruilian RDH1225S, which run at 0.4A. They're reasonably powerful and I'd like to 7v em.
I run them all in one chain from a single PSU Molex connector.
Then I had a thought. Since I run them all in a chain, then why don't I mod one of the fans wires rather than stick in a modded Y splitter.
Just a sanity check here.
I'm going to swap over the red and one of the blacks (the one beside the yellow, which is the one the fans power from) and that'll give +12/-5=7V rather than +12/0=12V or -5/0=5V (the other volt mod for fans).
I'll only need to do it once, since the fans are all connected in serial they'll get the -5V to their 0V and run at 7V too.
Right?
Right?
