Crysis demo - does it work on Vista x64?
12 Jun 2004
Exeter
I built a new PC recently and wanted to try Crysis out but everytime I try to install the demo it comes up with an error. Does the demo work OK on Vista x64?
I've tried downloading it from two different sources to no avail.
I had vista premium 64 running and I couldn't get it to work but then again I'm not that technical and patches etc may have been released since then.
Sorry I didn't explain the problem well enough. It wasn't actually an error. It seemed to install OK but it didn't put any shortcuts anywhere - I tried searching, looking in start menu, etc. :eek:
After a bit of googling I found it is located in the bin64 folder in program files. :confused:
Anyway, I have it working now. :)
LOL if it doesn't put shortcuts just go to it's program file location and make one for the desktop from the .exe :p
Alternatively look in the 'games' folder within Windows, some games like to pop a shortcut in there instead. I'm pretty sure Crysis does.
Yeah lots of games on vista only have a shortcut created automatically in the "games" section on the start menu.
