Changed my mind yet again. PLease help me make a decision!
tested it?
Nope. :p
The electrics are not in yet!
Anyway is guaranteed for life and to work and I have designed it so at a push I can take it out again. :D;)
Cost a lot of money though:eek::eek::eek::eek:
May sound obvious but some speakers require more powerful amps to be driven properly for varying reasons, not to mention different speakers carry different audio signatures, and amp will still have its own signature though, so both influence the sound in varying ways. See enough people with w**k quality audio because they've paired an awful source with good equipment, or terrible speakers with a good source and you'll see what I mean!
Good skills, which one did you buy?
100% Pure Digital Performance = Picture Perfection.
19 Pin Backwards Compatible Type A Male Connectors
24K Gold-plated Connector Plug Contacts
Category 2: tested to carry up to a 340Mhz signal (up to 7m)
Full support for 120 Hz frame/refresh rates, 12-Bit Deep Colour, x.v.Colour, Dolby® TrueHD and DTS-HD
Fully HDMI Authority Certified
Highest specification, latest revision with 10.2Gbps future-proof high-speed bandwidth
Highest-grade oxygen-free copper
Latest revision version 1.3b specification & Full-HD 1080p resolutions supported (inc 24fps)
Protective nylon material cable jacket
Real-world tested to support Full HD 1080p/60hz up to 15m
Superior professional robust build-quality & durable construction
Triple mylar individual cable screening for maximum interference shielding
Unique HD Cable Patented Metal Headshell Assembly
Zero Data Loss
i hope you didnt pay £50 for that lol.
Easy, dont even listen to anything WhatHIFI has to say. Onkyo's might well be great HT amps but whatHIFI are well knows for pushing whoever wants to advertise in their mags. Home cinema mag is better but if you want nutrality you HAVE to ask on a decent online foru,.
Whats wrong with the cable?
I bought it from a company that is on the HDMI Adopters list. And they guarantee it will work.
I thought 49.99 was ok: :p for a 15m cable?
Just to mix it up a bit = I took my Onkyo 606 back to the store (it started to buzz the 2nd day I had it) and got a black Denon 1909 for £339 new.
Im so much more happier with the Denon. The sound to me is fantastic for HT and music listening and it looks far better than the 606.
.... The 15m HDMI pro-2 cable would have done the same job for £15 cheaper. And you can can get 15m hdmi cables cheaper than that, that would also do the same job.
Those £50 Platinum's arent actually any better, Easyrider.....
Is that all?
I was getting worried.:p
15 quid is nothing in the grand scheme of my home cinema room build.
so is the hdmi pro-2:)
All our cables are fully HDCP compliant, and HDMI Authority certified. At HD Cable we believe in one cable for life! All our cables come with a worldwide lifetime guarantee included.
