What remotes do you use for your HTPC running Vista Media Centre?
Get a Harmony so that you can control your htpc, amp, sky, tv, pj etc aswell.
I've got one of the cheaper models but it's still really good, except for the programming software which isn't.
It can take a while to set up but once you've set up each 'activity' that you'll use, it's a breeze.
Does the Harmony 1000 work with Vista media Centre to control the HTPC or does it just control the AV equipment?
A google doesn't bring much up on it
As long as you have an IR input. So you still have to buy a remote, then program the harmony to emulate that remote.
I would recommend the M$ one.
Microsoft Media Center Remote does this come with a usb RF version?
This one is IR meaning it needs to be in direct line with HTPC
Are you using the Antec case as I think that has an IR built in?
If you're putting the amp, htpc etc in another room you can use those IR spot things (not sure that's the right name!). I think Angel Eyes on avforums uses them as his kit is on a cupboard outside of the room.
i use the ms one, the reciever is really good tbh, it never 'misses' -unless using the keyboard, then you lose the odd letter, probably to do with my knee being in the way of the keyboard tbh
