1920x1200 vs 1920x1080 @ 24"
10 Oct 2007
kidderminster
Hey overclockers!
Im planning on upgrading from a 22inch 1680x1050 to the specs above but im not sure which to go for? any opinions would be greatly appreciated;)
Depends which model of monitor you are looking at. If it's being sold as a monitor then it should at least support 640x480 so you can see the boot screen. The only exception to this is that I'm aware of are certain models of the Apple Cinema Display, but there may be others, read the spec sheet for the model you are interested in.
Don't worry too much so long as it'll show 640x480 and it's native resolution, you can use the scaling built into your graphics card to acheive any other resolution, even non-standard ones like 960x600.
As for your original question, would you rather have a 16:9 monitor or a 16:10 monitor, the latter is squarer than the former and thus will result in small horizontal bars while watching widescreen films, with the trade off that when watching 4:3 films the vertical bars will be smaller.
That's because most films aren't made in 16:9, 1.85:1 (16.65:9) and 2.35:1 (21.15:9) are the most common.
The 1.81:1 stuff is most likely to end up with a mild crop or pan&scan for the BluRay release but to crop a 2.35:1 film would have the home theatre crowd complaining louder than all the people who complained about Bioshock.
I agree that 1920x1200 would be better for computer use, especially once you take into account the taskbar and your application's toolbars (or that ****ing ribbon) reducing your vertical space even further.
No, he's right on this one (unless it's Bioshock 1.0 or FarCry 2) the wider your screen the further you can see to each side.
However you are also right in that you can achieve the same effect by running your game in 1920x1080, you just end up with small horizontal bars.
either, there's bugger all difference! there has been a few threads on this previously and it just decends into arguments. seriously the quality of the display is far more important that the (small) difference in resolution.
For a 16:9 image:
Image Dimensions: 20.93" x 11.76" on the 16:9 panel
Image Dimensions: 20.35" x 11.43" on the 16:10 panel
Equivalent 16:9 TV: 23.3" for a 24" 16:10 panel
I think losing half an inch of picture in a film is worth having a better desktop resolution :p
