Hi,
Will an 4870 card fit inside an Antec Fuion HTPC case, I have an 3870 already but am considering upgrading but need to confirm it will fit and if so which card/make ?
TIA
Brad, my Xpertvision variant are on the sideSo that`ll be the same for the Palit and Gainward too?
I managed to fit a Sapphire 4870 1GB inside my Antec Fusion case, one of the new cards with the heatpipe cooler design. Length wise, the card fits, the lower 6pin power supply plug does not go in due to the hard drive section wall, you'll have to cut out a small segment of the case wall here for clearance. Height wise, the heat pipes on the card just about fit inside the case, you will be able to fit the lid on OK.
Only other thing to take into account is the width of the card cooler and how many SATA ports it may block on your motherboard once fitted inside the case. Good luck!
Whats your full spec? does seem a little low but these cards stretch there legs in games and ati unlike last round are not bothered about 06. Try running vantage.
Yea not to bad with the quad running at stock i would oc that quad to 3ghz to get the best out of your 4870 and it would make your 06 score much better also. As i say anyway the difference you will notice will be in games not benchmarks.
