Had a really strange problem last night
Switched the computer on to be greeted with a blank screen once the PC had booted up. Windows is running fine in the background but nothing is displayed on the monitor.
Machine boots fine in safe mode. And if you delete the GFX in device manager it will also display fine once it boots up. Its only apon installing any ATI drivers do i get this issue.
I am able to VNC onto the machine from a laptop so i know everything is working fine. The refresh rate is set to 60 so the monitor should display it fine. like i say it all works fine right up until i install ATI drivers.
so the card works ok and so does the monitor as i can display fine without drivers........soooooo any ideas?
Cheers
Brian
Cheers
Brian
