I know what an opinion is. "sigh"
Clearly not else you'd know that an opinion doesn't require any proof or 'backing up'. The statement wasn't one in any case, I was merely pointing out that I may or may not correctly recall there being a case that EULA's were not enforceable.
It is however my 'opinion' that MS would have a hard time prosecuting a user in court for using an apparently un-licensed copy of OEM XP after they installed it on a new motherboard and MS themselves activated it either via the net or phone line with no questions asked, and as that is an opinion I do not need to back it up, understand?
I think it is a little irresponsible to state that you "believe" that the Windows XP EULA is "un-enforceable" and then not back that assertion up.
It's even more irresponsible to take something I have already stated may not be correct and assume that I am making a defacto statement.
This forum is used by people looking advice and guidance and to not back up assertions is a tad remiss.
Again, what assertation?
You can continue to attempt to twist my comments into something they are not or you can accept that you have misunderstood what I wrote, either by me not being clear or by your failure to understand either way amounts to the same thing.
To re-iterate and make clear to you:
1) I seem to recall that EULA's are not enforceable in the EU, I do not have any evidence to back this statement up, I could also be failing to recall the situation correctly and as such you can either take it or leave it but I will not be spending time trying to google it.
2) MS will activate windows OEM via the net or by the phone when a new motherboard has been installed.
3) It is my opinion that due to the above that MS would have a hard time prosecuting anybody for using a technically unlicensed OEM copy of windows.
