I found this on gta forums and works unbelievably well
here is the best tweak for this game yet, well worth doing
my bro's system is stock q6600 with 4gb ddr2 @ 800 and a 8800GTX with the tweak he is getting pretty solid very playable fps with 1080p res / textures on high / rendereing on high / view distance of 15 / detail distance of 40 / vehicle density 60 / shadow 1
it has also benefitted my 4870x2 big time, forget about the so called system of the future when you already have a power house pc which handles crysis just fine
i am so glad i did not change back to a fast dual core as i almost did, this game uses all 4 cores, atlast the quad has really come into its own in a proper game
original tweak from here, max respect to the guys at gta forums and MonkeyMhz for making the guide, it is an in depth and easy to follow guide as long as you read it properly
http://www.gtaforums.com/index.php?showtopic=384473
to make the commandline.txt as mentioned in the guide above all you do is make a new text doc and rename it to commandline.txt open it and add your command line like "-availablevidmem 2.0 -height 1200 -width 1920 -availablevidmem 0.80" without the quotes, then save it and drop it into your gta folder where the game is installed and your done and can enjoy the game.
