I think the tower case is just great, If you look the MM webiste they have a few internal shots and the inside is great and has MASSIVE water cooling options.
Im hoping we can get the tower ones. But at the moment they will cost a lot due to the $ rate, But lets be honest there isnt a case like these on the market today.
The mm cases are amazing, but they are huge. Loads of space to work in as well. I can get 9 hdd's, and 10* 5 1/4 drive bays. I havent water cooled it yet, but i will when i get some cash together. Build quality isnt up to Lian Li standards but is is good. The paint quality is good as well. Mine also didn't come with any usb ports or mic and speak inputs.
Have to admit I'd been thinking of a duality version for when I get around to building an i7 rig at some point in the future, then I could stick my current rig in the other side (both under water) just to keep going as a media centre rig. To be honest though that's a long way off unless I start playing lotto!
They are good, but they cost the world and id be much happier with Lian Li PC-V2010B and £100-200 extra to spend on powdercoating and asecond graphics card to crossfire my 4850
they are fantastic - anyone looking to buy one should post so we can gague interest
would be a great alternative to lian li/silverstone for a high end case buyer - just for the individuality
i know TiZoR is keen on getting one - how have you guys got yours?
imported direct or through the uk supplier? was the wait long? [please try to just disclose wait times and not refer to competitors]
however to buy enough for sustained stock may cause problems
fingers crossed as they would be great to have [and build in]
