T1-R's are great for what they are, a budget performance tyre.
When you compare them to other tyres in the price bracket, i.e. Pirelli P6000s, they really are good.
I had a set on my 160hp Charade Turbo after using Yokohama semi slicks for about a year, there was very little difference in dry grip. The Yoko's had a very very stiff sidewall, so there wasnt a huge amount of feedback on the limit of cornering, where the Toyos had a softer sidewall, and hence were more progressive.
That said on something like like an EVO or a Subaru, or anything capable of high cornering forces, that may not be a good thing as the sidewalls will wear quickly in comparison to the rest of the tyre.
