Would reccomend the TRUE black,
http://www.overclockers.co.uk/showproduct.php?prodid=HS-056-TR
Or the tuniq tower 120
http://www.overclockers.co.uk/showp...CPU Cooler (Socket 478/754/939/940/AM2/LGA775)
You should be fine with either in an eclipse, just installed a window panel in mine tonight, now need a few lights to bling it up a bitThanks guys, I like the look of the Tuniq, would look alright in my case which has a clear side panel. The case btw is an akasa eclipse!
The TRUE is a bit pricey though, £40 for a cooler is just way too much for me. Unless I find a cheap one of MM![]()
You should be fine with either in an eclipse, just installed a window panel in mine tonight, now need a few lights to bling it up a bit![]()
