As per title, i'm curious if there's any games that the 4850 512mb can't handle atm. The reason i'm asking is that my 8800GTX recently died on me (best card i've ever bought, lasted almost 2 years and still played everything fine) and i'm looking for a replacement.
I had a look at tomshardware benchmarks, but i find them annoying as performance fluctuates on all cards depending on the game you're currently playing and i find it hard to judge a prospective card from them. Plus looking at the benchmark from crysis, the 4850 comes in just under the 8800GTX and the 4870 comes in just above the ultra.
I can just afford a 4870 if i have to, but with the time of year it is i'd rather not unless it's necessary. I run on 1600 x 1200 resolution, the rest of the pc is half decent.. 4gb ram, e6850. I just need a bit of advice before i buy another card from OC as i dont want to end up getting the 4850 and then find out that i can't max out newer games on it. I have £250 spare, but i'd rather spend much less than that if possible.
Be as honest as possible please and no telling me to get the 4870 without telling me why. I know a lot of you are prone to recommending that one right off the bat
Cheers.
Edit - forgot to say that the PSU i'm running is a 520W Corsair, not sure if that'll make a difference as to card choice. I assume that power consumption has continued to climb with each of the new cards that come out.
Cheers.
