- 27 Jul 2005
- The Orion Spur
what a ridiculous list of pros and cons.
Can I ask why ?
just to stick my face in...
playing fable 2 and noticed the 360's rumble was stupidly powerfull. Kept falling off my leg and/or buzzing my nuts to death.
Yeah, you can either select 'Shut down system' from the main menu, or just hold down the PS button on the controller and do it straight from there. The 360 has the same sort of thing too.
It will if you get one of those cheap PS3 remotes that use an IR dongle and learn from that - obviously youll have to keep the dongle in but your Harmony would work with it thenLogitech Harmony.
Hit power off and it turns off my TV, XBox and AV amp
However this wouldn't work on the ps3 due to it being bluetooth
the 360 also has the better controller (sans D-pad), i don't think this is really deniable, if you have anything other than 10 year old hands it'll be more comfortable.
Yes, it mad m dstroy all my christmas prsntsAnyone else get annoyed with people spelling "Blue Ray" incorrectly?
Its Blu Ray, kthxbye.
Completely opinion based, I prefer the DS3, cant say I have 10 year old hands either.
Yeah get both, I play games on 360 and use the ps3 for all media streaming, awesome setup. I wouldn't bother with either though unless you have a hdtv first. Tbh I never notice the noise of either over the noise of a film/game. The controllers both have there pros and cons although to me the 360's is better overall, just dont try and use the dpad ever.
