- 18 Oct 2002
- Manchester
I've bought an HIS 4850 ICEQ Pro from here and had nothing but aggro with it. I've sent it back for RMA only for it to be returned and told it works perfectly.
Before I try to send it back for a 2nd time can someone please confirm wether this is normal or not?
I haven't even got as far as installing windows with this card yet as the montir keeps going into standby mode and won't come back on. This happens wether connected using DVI or HDMI to my DELL monitor and obviously makes installing windows impossible as the only way to get the monitor back on is to reboot the PC...
The fan on the card spins up and then just stops, sometimes it will spin back up, other times it won't and the monitor goes off. The heat coming from the card is silly, it's getting very warm indeed and that's just in the BIOS with the case open!!
Do these cards throttle down and stop the fan spinning altogether or is this card faulty as I first said it was??
Thanks for any input
