Odd thread maybe however;
Looking to take down a small "wall" of placed stones which hold back/supports our garden. Its only about a foot high but wish to move it and make it a bit straighter. Was going to re use the old stones (without mortar) but the misses now says she would like bricks.
So now I need some advice, it will only be about 4 bricks high (compared to standard house bricks) however;
1) what sort of foundation/rubble do I need underneath?
2) are there special bricks I should use (wider than house ones?)?
3) do I need some sort of barrier (rubber?) between the earth and bricks?
4) what do I "top" it off with?
5) Brick laying kits, now I prob wont be good but want to DIY it as it shouldn't be that hard however I have seen kits for ~£30 that you lay on top of the brick to give the right level of mortar are this any good?
Any tips/help/websites would be good.
Cheers steve!
Cheers steve!
