Barbs for 7/16" ID tubing
29 Dec 2003
UK
can someone confirm these are the right barbs for 7/16" ID tubing.
http://www.overclockers.co.uk/showproduct.php?prodid=WC-006-EK
Bought 12 lately from 2 other places and 6 are right and 6 are wrong,
These are as they were listed
6 x EK 3/8" ID fitting G1/4" "High flow fitting for 3/8" ID tubing"
and
6 x G1/4" to 3/8" Hose Tail (EK) (EK1438)
Ive mixed them together so not sure which of the above are the ones that are fine :o
I stayed away from the EK G1/4" to 1/2" as it read the barbs were 14mm but now im thinking that might be right and somehow ive fluked 6 that are ok.
Cheers
As pegasus1 said 1/2 barbs. The tubing will fit very tightly with no need for any clamps on the tubing.
