Hey Guys my dads PC 7600GT is dieing once again, im currently using it to play Left 4 Dead till my Mac Pro Comes. which now could be March-June. he only browses the internet.
so im looking for a cheap Gaming Card that is good as 7600GT if not bit better thats cheap.As i been out of gaming for a long while i have followed the cards so hope you could help!
all i need it to run is 1204x768 all medium would do as thats what 7600GT does no AA ovb
Hes Spec's are as follows.
AMD X2 3800+
DFI NF4 Lanparty UT Ultra-D
1GB Crucial Ballstix (might get him 2gb kit)
7600GT BFG Stock OC
400GB HD
580w Hiper PSU
thankyou
edit just to update i bought the 3870
GPU Clock - 775Mhz
Memory - 512MB
Memory Type - DDR3
Memory Speed - 1800MHz
Memory Bus - 256bit
CPU Bus - PCI Expressx16
HDCP Support - Yes
all i need it to run is 1204x768 all medium would do as thats what 7600GT does no AA ovbHes Spec's are as follows.
AMD X2 3800+
7600GT BFG Stock OC
400GB HD
580w Hiper PSU
thankyou
GPU Clock - 775Mhz
Memory - 512MB
Memory Type - DDR3
Memory Bus - 256bit
HDCP Support - Yes
