Apparently Valve have said that if Steam were to ever go under, they'd release a patch for all users which unlocks the games they've got tied to their account, meaning you'd be able to access them without the online checks.
You're right to be cautious, but I think you're probably safe in this case. It's by far the most successful digital distribution platform there is for games, so it's probably the least likely to disappear anytime soon.
Bought myself ID Software pack, turns out complete waste of small change, none of the Q3 based games can play full screen (opengl "fullscreen unavailable in this mode" error in vista) and when launched in window display gets corrupted as soon as that Steam online community popup appears in the corner. Absolute rubbish release.
Yes because I'm sure it's the software and not your particular combination of build and drivers that are the issue...
Has anyone else noticed the mouse acceleration in Bioshock? I've checked the config file but can't find any setting that turns it off. Sensitivity is down to 1 but it's impossible to quickly aim with precision :/
I thought it was just me. I'm glad I'm not the only one thinking this. After getting to the point where the crowbar no longer sufficed I really started to notice it.
Don't meant to go off-topic, but if you're downloading something off steam but need to close it down, will it resume the download after you restart it or will it start from the beginning again? Will the game become corrupted in anyway?
It is their software. All the rest, driver versions and hardware configuration at this point is irrelevant - original release works flawlessly, Steamed doesn't. Same happens with RTCW.
crazy.. I just installed the Q3A demo on Steam, and I got the exact same problem. I own the retail version of Q3A, which runs flawlessly.
Something is definitely amiss with the Steam version :/
Just bought farcry 2, any good?
completely depends on your tastes. just play it, dont let the strong opinions that are floating around influence you to much, especially now that you have bought iti liked it
