120.2 for cpu and gfx
I wouldn't bother with water-cooling on that basis. Get a nice sparkly case like the A05, do the dual blow-hole mod, and with better case cooling, you'll get those temps down a touch and with quiet fans you'll get the noise down too. Do that first before you take the plunge into water-cooling.
I understand. I'm just saying that the margins we all used to care about are no longer so fine. Suppose you have a heatload of 250W. You have a 120.2 rad with quietish fans. The rad may not do a great job of cooling the water resulting in a highish delta between water and ambient.
Water is amazingly good at removing heat. It take a massive amount, relatively speaking, of energy to raise its temps by one degree. The rads are also very good at exchanging that heat to air with the shear amount of water that passing through them, mass flow rate. So we see air/water deltas well below 10C. More like 4C at idle. Trouble is getting the heat out of the cpu core and into the water, there just so much energy you can transfer over a limited surface area. And the blocks are now at the point of diminishing returns, massively improved re-designs only see a degree or two improvement. And they simply can't get any better. Apart from the concave/convex IHS to deal with, between the water and the core is the block itself with its proportion thermal resistance TR. Then there's the IHS to solder to core encapsulation again with its TR, then to where-ever the DTS sensor is located on the core. All this adds up to an, err, interface bottleneck for the want of a better description.
Rads, cooling can be odd things to deal with, chucking more rads in a system doesn't always give the logical result. Doubling the rads may have little effect if the system isn't heat saturated. More pump flow makes next to no difference once you're past a certain point. Even increasing temps from the pumps heat load. And there's the mass flow rate of the other coolant, the air. The rads are very sensitive to the cfm of the fans, its the one thing that we can really improve on.
Does it matter?
I contend that it doesn't. Blocks are incredibly efficient and the chips can stand very high temps compared to five years ago. So what if the water-air delta is very high? So what if the resulting cpu temp is 60C? All I'm saying is that a 120.2 will handle enough heatload to stop a modern chip from overheating.
Up to a point no I guess it doesn't. With GPU's it makes little OC difference, sub 80C they could care less. My early C2D cpus chips had a tendency to get flaky with higher temps. The last few wolf/yorks I've had were less bothered by higher temps. After all the typical Tjmax on these things is 100C, the designers are happy for the IC to get plenty hot before they even worry about throttling. Remember though, the Engineers rule of thumb says for IC's
-10C = ~+2% frequency increase, OR x2 life at same freq, same voltage
By then I've sold it anyway, so meh. I have to say though these Ci7's are a different beast. They can take much higher temps and remain stable, but the heat they dump is amazing once the volts get going.
I have a Noctua on my CPU with a single fan and an accelero on my 4870 with a single 120mm fan.
CPU idle is 35deg and 4870 idles at 40 deg.
Under load CPU hits around 57-60 deg, not sure on GFX card though.
Those are good temps really. Water is nice, but don't expect it to change much, at least not on the overclock. Like I said a PA120.2 with reasonable flow, any DDC. And reasonable fans, medium speed Yates, with dissipate 250W all day and keep good temps with those two. If you go to silent fans temps be worse than you're getting now.
The way I see it is that this upgrade should last me a few years. For my next upgrade to just have to buy new mother board/ cpu/ gfx and just have to buy a new gfx block (CPU block has 1366 fittings).
Also, it'll be a bit of a project for me, I understand the temps might not be better than my current set up, that's fine, as long as they are no worse. The whole loop + case comes to around £300. I can sell my noctua and accelero (old case will go in the bin!) to get a bit of case back but I am definitely doing it more for the atheistics than the performance. The only thing I don't want is for it to be worse than my current set up.
And why not, water is a nice project. Quite satisfying getting a system all plumbed up and running. Get some good medium speed fans that you know will run at low voltage. Then as Mike says, put em on a controller set them where you like. Good water kit will last for years if you maintain it. I always say get quality gear to start with, you'll only end up replacing it with the good stuff anyway. Filling and topping off can be a pita, you might want to add a fillport if its all internal.
I dont upgrade very often so it won't be constantly taken apart. I have the fans and will look into a controller for them.
Should I look at getting clips for the connections of the tubes or will they be fine? (7/16 tubes on 1/2 barbs)
Thanks for all the help
sorry to highjack! but people following this thread seem to actually know what they are talking about :)
I'm looking at WCing my rig (as in sig)
1 to reduce noise (my 3 stock gpu fans +cpu fan are loud at full)
2 to reduce load temps (my components will go a lot further had my q9450 @ 4GHz but am temp limited atm)
question is would a single AND triple rad + MCP655 be enough to cool 3 8800gtx's + my chip?... in one loop?
cheers
A lot of people chance it. Personnely I'd never leave a pipe without some form of clip. Zip ties work well, or those black ratchet clips if you dont want to use jubilee clips.
Thanks for all the help, I have ordered everything (though unfortunately not from OCUK since they didn't have everything in stock so fingers crossed it turns up!)
Should be here on Tuesday hopefully! I'm sure I'll have plenty more questions when it arrives.
One thing I did want to make clear was the order of the loop. Should I treat it any different since it is an inverted case?
I was thinking pump/res>cpu>gfx card> rad
Cheers
Don't worry too much about the order, just stick to the practicalities. Res before pump to prime it is the most important. Generally most take the output of the rad straight to the cpu inlet rather than the pump as you have it. Although technically (I won't bore you with why) the loop order makes very little difference to temps.
What would you estimate the heat load to be? 500W or so? The cards won't all be running 100% in SLi. Do you have any power meter readings? Its a bit hard to estimate that one.
You're considering what? A PA120.1+PA120.3? I'd guesstimate looking at the charts for those two with typical medium fans around 500-550W heat dissipation.
Cool, I guess it would usually be easier to do it that way anyway but with this being an inverted case it makes it a bit trickier.
Then don't worry about, as long as you can prime the pump. Go for the tidiest install. With the kind of flow rates in your loop the maximum delta anywhere on the loop would be around 0.5-1C for 250W heat load.
Fag packet calc below, in case anyone cares.
dQ/dt = cM (T2-T1)
where
Q is heat entering the coolant, once equilibrium is reached its the heat leaving the radiator.
M is mass flow rate (for a pipe its density x velocity x area)
c specific heat capacity
T, delta T, difference in temperatures from inlet to outlet
A DDC with two blocks, flow at least 1.5GPM (6.81 Ltr/M) & 7/16" (11.1mm) bore pipe. The water moves at 1.172 m/s. A 250W heat load. Water at 22C has a density of 997 kg/m3 giving a mass flow rate of 0.1133 kg/s, specific heat capacity for water is 4186 J/(Kg°C)
M= 997 x 1.172 x ( π 0.0111²/4) = 0.1133
T2-T1 = 250 / (4186 x 0.1133)
Therefore delta = 0.527°C
Just means 0.5C across the rad inlet to outlet, or 0.5C across the two blocks (ignoring pump heat load as its small).
