Hi Guys,
This isn't my boiler so i'm a little unsure as to how it works!
It is on a timer so I generally do not mess with it. However yesterday the house was a bit cold so I turned it up. Come that night the house was very hot so I decided to turn the boiler completly off. (To the 0 position)
This morning I turned the thing back on, to the radiator and tap position and turned both of the heating dials to medium ish.
However a few hours later the boiler has done nothing (it did make nosie for a while) and the 60 degree C (circular symbol with a triangle in it) is flashing red, and periodically the tap icon is flashing screen, but then returns solid after a bit.
Also the pressure guage is sitting at 0.
I have made sure the timer is not interfering (have set it to permenantly on)...
Any ideas what could have changed over night ?? Should I have not turned the thing off?
Checked on the web and it seems the 60 degree C light when flashing red indicates a pressure issue :s
Would appreciate anyone who has one that could shed a light!
