- 8 Mar 2007
- Poole, Dorset.
How much storage have you got all together there?
Also, have you tried your heatsink in a different orientation? Like 90 degrees so its airflow is inline with the intakes and exhaust fans? I found it works better than when I had mine how you've got yours.
5x 1T and 750 gig (windows)
I have a Thermalright Ultra-120 Extreme cooler and it does not fit inline with the intakes and exhaust fans because it touches the psu rack above. The holes in the mobo tray should have been a little bit lower really...was very annoying at first, but my temps turned out ok in the end.
