Caporegime
- 8 Jul 2003
- In a house
Btw, are those clocks they used for the 280, pretty easy to achieve on a stock 280? (not really been following any oc 280 threads). - thanks, joe
Interesting read. One thing it doesent simulate though is how far on average, a 'stock' 285 will be overclock by, and what figures that will give.
its quite relevant imo, it gives you a point of reference.
They should really stop comparing the 4870x2 with single cards, its completely pointless.
How?
A reference that 2 cards is better then one? That's obvious.
Surely when testing cards you need 1 card, 2 cards and 3+ categories?
No it's not in the slightest... it is ATI's fastest enthusiast-class card sold as a single solution, and can rightly be compared to NV's leading enthusiast-class card. That it is essentially two cards has nothing to do with it, and it's NV's fault for not having a comparable solution to compare it to.
ok...i'm looking at a 4670 but how fast is it compared to a 4830? according to you, the two should never be tested together.
rubbish tbh, id rather as many cards tested together as possible.
What stupid review would that be, how are we supposed to know where it stacks up if you cant compare it with any card![]()
It has everything to do with it, the comparison criteria is not the same over the 2 cards making the results completely pointless.
