Lian-Li V1000Z Build
20 Aug 2007
Hi All,
Just got my 1000Z today, and am very impressed with this case. It is a lot more compact than I expected, but moving from an Eclipse 62 I happily managed to fit in everything. It feels smaller than the 62, but in a good way if you know what I mean.
The quality of the case is excellent, and I especially love the drive bays in the bottom compartment. The only annoying bit is the PSU sticking out the back, but not a big deal.
Anyway, attached are a couple build pics for your viewing pleasure...
Motherboard (P5Q Deluxe with Q9550) and power supply (Enermax 720W) installed:
Cooler and hard disks added:
The finished product:
Very pleased with how it has turned out - cable routing works really well in this case even though the cables for the front connectors (USB, audio, etc) are numerous.
Looks pretty sweet, i dont think lian li have made a bad case, maybe just some not as good as others :D
The v1000z is looking sweet!!What's the cooling like in their?
I'm running a Noctua NH12F cooler and all standard fans and have clocked the Q9550 to 3.6 - idle I'm getting about high 20s degrees on each core with CoreTemp and high 50s on full load with Prime which seems pretty good to me.
I'm running the side 140mm fan that I think quite a few people remove due to graphics card size, but I've managed to just about fit it in.
Looks good. How did you find the I/O shield alignment? Can you post a pic of the back?
On mine, the ports on the motherboard are about 2mm too high for the I/O shield openings. Any higher and I wouldn't be able to insert any USB plugs.
The alignment wasn't spot on, but I think a lot of that is to do with the new backplate that you get with the Asus P5Q - it is padded so the connectors push right on to it and there isn't much 'wiggle' room. I can get all the connectors in, but if the alignment was out by another 0.5mm then I probably wouldn't be able to.
I'll grab a pic later today and post it.
