The other week, I was testing the DC output power of the 3v power adapter for my alarm clock because it ceased working. I used a digital multimeter, and to my surprise it was outputting nearly 6V DC, despite the label clearly showing 3V
Whilst I still had my multimeter out, I wondered if it was normal for old adapters to output tonnes of extra voltage and/or current, and so I got out all my other power adapters I had sitting in my man drawer, and started testing them one by one (yes, I was bored
Turns out, nearly every power adapter I had that was supposed to output 12V DC now gives between 18-20V, which is bad in itself, most outputted 5x the rated amps, and one of them which was rated for 1000mA turned out to output just over 9 Amps (9000mA)!!!
That's more than enough to kill somebody, surely?
Just to put that in perspective, most standard plugs have 13 Amp fuses, and that's meant to be pretty extreme to say the least, meant for such situations as the live wire being shorted. Suffice to say I threw out all the dodgy power adapters, before somebody plugged them into something and fried the hell out of it.
Then I had an epiphany... perhaps the reasons I have all these spare adapters and no corresponding appliances was because they were most likely thrown out after being fried... by these very adapters.
I did a quick search around on google to see if there were any articles on old adapters losing their voltage reduction capabilities but found nothing.
Anyone else had random appliances die on them for apparently no reason? Perhaps check the actual DC voltage of the power supply adapter and you may have your answer
