Looking to get a new mixer and CD deck and a pair of speakers in the new year and i'm looking for some advice n suggestions
Budget is around 1200-300
Mixer wise i'm thinking Ecler Nuo 4.0. Needs to be 4 channel (preferably with all 4 being able to be in use at the same - so dedicated mic channels too). I've got 2 turntables, the CD deck and i'll be hoping to get Serato soon as well. Build quality is important, i've been through countless Vestax mixers which are considered fairly good. Not bothered about sound effects, a nice amount of outputs would be nice (which the Nuo 4.0 has).
CD deck - Pioneer CDJ400 or 800, I like the idea of the USB input on the 400 but is the 800 better built/all round nicer to use? There's not much difference in price...
Speakers, no idea....I'm currently using a pair of Behringer Truths and they're amazing (suprising for Behringer!). I've also got a pair of Alesis MK1's on another setup and they're just too bassy, ends up distorting all the tune so room compensation/bass reducation/treble reduction controls are important
What would you lot get?
