Seriously, I could tell the difference from 8 feet away and at quite an angle too (quite a lot of us crammed around the TV).If you plan on watching Pixar blu-rays at a distance of about 3ft from the screen while looking out for the tiniest bit of jagged edge or poorly gradiented colours then get the z series.
If you need to be 3 feet from the set to notice the difference then I'd seriously suggest you get your eyesight checked.
If you wanted to do a blind test twixt otherwise identical 720p and 1080p panels watching a Pixar film from a distance of 8-9 feet then I'll happily bet you £100 that I can identify which set is which.
