Tri-view?
6 Mar 2007
I have a dual-view setup at the moment but could really do with a 3rd screen to help me spread my work out more.
I have a 280GTX, so I imagine to get a 3rd monitor I'd need a 2nd GPU but do I have to buy another 280GTX or can I just get a cheap card?
Thanks,
Nick.
Yes, it will process the display with the card thats connected to it...
So just make sure you run your games on the monitor connected to the 280
Managed to squeeze all 3 monitors on my desk... only thing is, the new one didn't come with a cable!!! Grrrr, luckily a friend is in town to pick me one up. It's a shame companies don't include simple things like that (Asus, I'm looking at you!).
Friend got extensions instead of the VGA cable, lol.
I've tried 1 monitor on the 280GTX and 1 monitor on the 8400GS to test monitors on different GPUs and it works a treat. So can't wait to get the 3rd into my GPU.
What would you recommend, having my primary gaming monitor on the 280GTX only and the other 2 on the 8400GS? Or doesn't it matter resource wise?
i'd do what you suggest, 2 on the not so good card, it'll be more than enough to power two monitors for MSoffice, itunes, internet and the like, and have the 280 powering the 'main' screen, the one you will be using for graphically intensive stuff :)
On this line, will he be able to use the second card as a PhysX card as it is nVidia and still display 2D work? No idea on this but it would be handy to know :)
- Pea0n
Got a new cable and my Asus monitor is all ghosty... the right hand side of stuff is ghosted like a motion blur. (EDIT: Seems my other monitors are now too, not sure what I've done, lol)
I tried resetting to factory settings and auto-adjusting but no luck! Tried different cables too. :( Any ideas?
Also the 8400GS is 1.78 where the 280GTX is 180 Nvid Drivers, what should I use?
Right I'm pretty sure it's software related because when I boot the PC up there is no ghosting until Vista loads up.
My LEFT screen is fine, no ghosting
However my CENTER and RIGHT screen has ghosting.
LEFT & RIGHT = 8400GS
CENTER = 280GTX
I've updated my drivers to the latest 1.80. Strange at why this is happening. The only thing I can think of is it being the Belkin Monitor cables, the LEFT one doesn't have one, the other 2 do... but they are brand new!
IT IS THE CABLES!
I bought 3 Belkin cables from Ripoff World for £30 and they all give my screens a ghost blur. So ****** off.
Sorry for tripple posts, guess there is nothing I can do but buy more stupid cables.
IT IS THE CABLES!
take them back for a refund, you have 14 days on that sort of item don't you? just go complain until they give you refund/replacement
