Cooking with Jonny69: Home cured bacon
Man of Honour
Man of Honour
3 May 2004
SILENCE!
Recently one of my friends had a crack at some home cured bacon and I was so impressed with the way it came out and how simple it is to do, I wondered why I'd never done this before. The curing process is quite simple: you take a slab of meat, rub it with salt and sugar and leave it to cure. You repeat this a few times over the course of a few days and then it's done.
I started with a nice chunk of free range belly of pork from the supermarket. This piece is about 600g and cost just over £3:
The rub is quite a simple mix, two parts salt to one part dark brown sugar and for extra flavour I've added ground peppercorns and a little coriander seed. You can also use juniper berries, honey or whatever takes your fancy. Here is about 6 tablespoons of salt, 3 tablespoons of sugar and teaspoon each of peppercorns and coriander seed ground together:
In a non metallic container (I've used a roasting dish) rub the meat generously on the skin side:
Flip it over and repeat on the bottom and sides:
Leave it skin side down, cover and put it in the fridge:
Curing time is largely determined by the thickness of the meat. 25-30mm thick will need about 36 hours and 40-50mm thick will need 48 hours. Go on the average thickness of the piece of meat, not the thickest part.
Day 2 is here! As you can see there's a lot of liquid come out the meat and that gets tipped away:
Take the meat out and rinse the outside of the meat under the cold tap and pat dry. You'll see it's firmed up quite a lot and it's a darker colour, less pink than it was:
Now you should wrap it up in greaseproof paper and leave it for 3-5 days to mature, then it's ready to cook!
Edit 1: when I first started this thread I did multiple rubs over the space of a week. We all found it made the bacon a bit too salty. After a bit of experimentation, I found the optimum cure was no more than 48 hours for a piece of pork belly. I've not edited the rest of the thread, so you can read it 'how it was', but bear in mind the bacon will be a bit salty if you make it that way.
Edit 2: back bacon here: http://forums.overclockers.co.uk/showpost.php?p=18247862&postcount=170
Edit 3: add saltpetre to the cure: http://forums.overclockers.co.uk/showpost.php?p=18247862&postcount=192
I do a similar thing but I add some maple syrup to my cure. It's quite expensive using maple but it is lovely. In a few months my first Parma ham will be ready and I can't wait.
Am I being a bit dense or is that a lot of salt for bacon? Or has it always been like that.
How much bacon will that provide btw? :)
The salt draws the liquid out the meat and you tip it off. Once the curing is done you rinse the outside of the meat and dry it off and it tastes like normal bacon but better. You can cure it for longer than a few days and it keeps longer but it will then start getting salty. It's pretty much the same as commercial techniques but minus the nasty preservatives and fake bacon flavours.
This should make about 450g of bacon so about two packs by supermarket weight, but it doesn't shrink when you cook it and there's no white slime.
Will any cut of meat do or does it have to be belly/hind?
Any cut apparently :)
*drool* :p
