HD4670 - Very Poor Performance
14 Sep 2008
Keeping 'er Country!
Happy New Year All!!
Now down to my problem,
I just bought a Sapphire HD4670 for my system. All went well when installing the drivers and software until I went to play games. When playing Counter Strike Source I get around 20fps on very low settings, the same result also occurs on Call of Duty 4. However playing something like 007 Nightfire or Carom3d gets fps of 65+, even with full AA and Filtering.
My System Specs:
Pentium D @ 2.8Ghz
1.00Gb DDR Ram
350 Watt PSU
XP Pro SP3
Any Ideas why I am getting such poor frame rates??
Thanks in advance,
Tom
My System Specs:
Pentium D @ 2.8Ghz
1.00Gb DDR Ram
350 Watt PSU
XP Pro SP3
Thanks in advance,
Tom
gonna have a guess here and say these two items are slowing you down and bottle necking your graphics
The Pentium D is dual core so I ruled that out??
The Ram is crap and I am looking into an upgrade at the moment.
The card is also PCI-E 2.0 and my slot is only PCI-E - I wonder if that makes a difference - it is running at 16x
It may be a dual core, but the netburst architecture of the P4 is archaic at best.
A dual-core 2.8GHz P4 is only equivalent to a Core2Duo running at about 1.4GHz.
And 1GB of RAM will get used up incredibly quickly.
The Mobo is an Abit IP95
Tight is around £75 because I am learning to drive next month
But then there is that plus RAM, and possibly a new mobo if there will be much difference in performance between PCIE and PCIE 2
Your CPU is by modern standards verrrryyyyy weak, doesn't matter if it's dual core or not, it's based on pretty horrible architecture.
Just save up for a few months then upgrade to a cheap Core2 system (you will need to by a new mobo, CPU and 2GB RAM), the difference in performance will be drastic.
I have a P4 3.4GHz lying around - that will fit in my mobo, would I see performance increase with this at all as a tempory solution??
Ok, so main upgrade atm is going to be RAM, will a 800Mhz 6400 stick work on my mobo? Assuming that the speeds slow down to match 533mhz mobo? Then eventually new cpu and mobo, correct?
