GTA4 breaking gfx cards??
27 Jan 2007
Anyone else had to RMA their card since playing GTA4?
I'm in the process of RMA'ing my BFG GTX260 OC; a replacement to my 8800GTXOC2 which broke 17th dec... yes it would seem GTA has broken two gfx card! My rigs been fine for a good year, even been through heavy 'crysis' gaming.
I've been solely playing GTA4 on and off since the games release and its this that which is e only change to my systm recently and thus must have caused the gfx cards to break.
My PC is a gaming rig so when not in use i turn it off. Could this turning off leaving the gfx card to cool down be causing the issue? I would assume GTA4 is very taxing on the gfx card and thus generating a high temperature under load - so once turning off its breaking the components?!?!
My spec is:
abit IP35 pro mobo
Q6600 @3.4
4gb 6400 ram
nvidia 178.24 drivers
I have a well ventilated antec P182 case.
Is it worth considering ditching nvidia and choosing a 4870?
Yea good point i was thinking the PSU... Its a corsair HX620 - 1 year old.
I dont mind replacing that if that would seem to cause such issues.
GTA4 has been very stable on my system not one crash!
I can't see it being the psu then as thats a quality psu. As said above it looks like a coincidence.
GTA4 didnt play too well on my hd4850 stability wise, it liked to mess up my shaders and textures a lot but after re-installing drivers and not touching anything i think its ok
I can hear my 8800 fan spin up quite loud in GTA4, but not as much as when playing fallout 3.
Your card may have broken as it's been stressed so something has gone wrong, though it will of had a fault to begin with.
This reminds me of when Doom3 came out and pushed a lot of overclocked cards over the edge :)
It's not the game itself causing failures, but it may be the game heavily using the card is pushing a borderline card over the edge.
look at your graphics drivers first
you have the 178.24
they are really outdated
im surprised no one picked up on that, but thinking bout it that wouldnt break a card.........
Define 'break'. I've got some potential issues with my new BFG GTX 260 OCX and it was tripping out a lot in GTA4. I found that dropping the graphics settings in game (with trial and error) have made it stable - although I do think I have an underlying issue with the card.
Break as in its broke the card as i cant boot up. It worked all fine the day before no issue, no overclock, just a long gaming session. Next day i turn PC on and gfx card fan stays on max and no display signal.
And i did try the 180 drivers but gta4 crashed a few times as they arnt stable for the game.
Pretty dead then!
I tried the newest (recommended but uncertified BETA) drivers and it locked up my PC continually, so I had to roll back to the certified ones (v180.84).
Well i'll be ******. i thought i was the only one....
bought gta on its release, and it played perfectly on my rig on med/very high, sliders nearly maxed out.then, i started the game one day and followed its advice to upgrade to the 180 nvidia drivers....
5 minutes after nvidia install, my graphics went spastic and my system locked up. rebooted to find the spastic graphics were blatantly apparent on the windows loading screen... all desktop icons were corrupt/distorted and my system locked up as soon as i touched anything. took the card out and tried it in my other rig and found the same problem! examined the gpu to find a nice burnt/delaminated bit of pcb by one of the power connectors. :rolleyes:
bought a 9800gtx whilst i was awaiting my rma and found i couldnt even run the game on medium, so decided to await the return of my 8800gtx...
... and now that ive got a nice new 8800gtxOC back, the game constantly crashes!
ive tried reinstalling xp pro 32, installing vista ultimate 32, and ultimate 64. still get random crashes/lock ups.
suggestions appreciated.
system spec - asus p5e3 deluxe wifi (bios 1303), Q9450 (@stock), 2gb ocz platinum 1333mhz ddr3, BFG 8800gtxoc (@stock with 180 driver), X-fi fatality extreme gamer pro, coolermaster 'real power' 850w, currently vista ultimate 64....
oh, and its all in a stacker 832 with 4 120mm yate loons on side and top, 2 stock 120mm fans and a thermalrite 120 ultra cpu cooler with another 120mm yate stuck on it...
