Hi,
I recently purchased the following system (against all my instincts, but I needed a system) - Advent PDQ5002 :
Processor Type AMD Phenom 9550
Processor speed 2200
RAM 4 Gb
Hard Disk Capacity 500 GB
Drive Speed (DVD/CD) DVD 16x DVD RW 16x
Drive Speed (CDRW, CDROM, DVD) 52
Graphics Memory 256 MB }
Graphics Description ATI Radeon X1200 } onboard
No of USB connections 4
I want to put a decenty PCI-express card in , and have a budget of around £200, I was thinking of the HD4870, but have 2 concerns....
1) this thing only has a 300W power supply - current internals are 2xSATA HDs (one from old PC) and SATA DVD/RW - will that cope, or will I need to upgrade that (in which case I'll need to look at a lower spec card, as I cannot afford to do both right now)
2) if it will, is it worth the extra few quid for the 1GB version? (again given the above spec).
Any advice/pointers gratefully accepted.
RAM 4 Gb
