Rampage II Extreme BIOS
23 Mar 2007
Kent, UK
I've been trying out different version of the BIOS for the above. Having a lot of problems with some of the later ones (70x, 80x versions) with things such as boot with no video or no POST whatsoever, anyone else had any of these issues?
Same problem here on bios 0805,cold boot problems :mad:
The beta bios 0901 is supposed to cure the problem but i've not tried it out yet.
I've fallen back to 602, seams to work perfect for me except that the RAID controller BIOS doesn't work, but that's the same with every version of the R2E BIOS in existance at the moment!!
The 0901 is also supposed to sort out the raid problems aswell but i'll just wait till it gets an official release.
Here is my bios which i meant to post a while ago...this is 3.8 and its rock solid,very stable
This is pictures from bios 1001
I am currently using bios 1101
i have exactly the same settings in the new bios 1101,i have found with bios 1101 i can lower my cpu voltage a little more than i had in bios 1001 that you see in the pictures.....
my cpu voltage in bios 1001 in the pictures is 1.375v....but in the bios 1101 that im using now i have it set at 1.350v....its a little lower and gives me the same results and is very stable....1.350v i tried in bios 1001 and it failed to boot into windows
This is for the rampage 2 board
