Hi I currently have a cheap casecom case. I dont like it becuase its loud its not well built ... its awful. I am looking for a new case for around £60 give or take. I am looking for a standard ATX size but will fit a ATi 4870. Any Suggestions?
Definitely This!!Lian li PC-A05B
**** off.! lol
antec 300 ***
I dont understand why anyone would choose the antec over the lian li, the build quality, looks and case design are way better.
In a word, price.
Lian li PC-A05B
The lian li is all of £5 more. (no not from ocuk)
Buy the antec if you are the type of person to put a wide arch body kit on your 1.1 vauxhall corsa.
 lolYea its about creating a flow of air through ur case so that air inside the case is replaced with fresh air and doesn't have dead spots (e.g. below ur gpu is a deadspot if u use a wb or silent heatsink). As the point is that ur heatsinks and can only pump heat into an area which has a lower temp (e.g. the air around the gpu). If this area doesn't have the air replaced the gpu heatsink will become less and less effective as the heat builds up until it cannot transport heat to the air around the gpu. Thought i'd give a more scientific reason for why the lian li is better. Also aluminium is amazing at conducting heat so ur whole case becomes one big heatsink.
