Blue Screens
12 Mar 2008
West sussex
hey
i've got a problem with my pc i keep geting blue screens in games such as HL2, juiced 2 in some races, track mania nations forever does it everytime the race starts :( some games like left 4 dead works fine never crashes blue screen says something about win32k.sys error tried renewing that file in case it's corrupted didn't work :( tried downclocking my cpu and gpu to stock speeds still the same.. tried new gfx drivers old set, new WHQL set and betas still the same :o
my system spec
amd x2 5000+ black edition @ 3.1ghz
asus 8800gt @ 700/1750/2000
4gb of geil low latency ram
2 hard drives 1 sata 1 ide
motherboards asus m2r32 mvp
psu antec 550w
runing windows xp 32bit
should i try swaping my ram sticks? maybe one of them is faulty? :(
any help appreciated
if you have installed the latest nvidia drivers then this could be the problem. 1st time i installed the new drivers (180.48 i beleive) i got BS in Left4Dead but re-installed them and havent had it since.
completely remove any form of GPU drivers before you install any more new gpu drivers. im quite sure that the new nvidia drivers are to blame and a quick hunt around other forums suggest the same.
If you really want to test the ram, just run memtest86 on them over night to see if it comes up with any errors.
After that you could eliminate out which is the faulty stick. (If you actually have a faulty stick obviously)
Yeah, run driver cleaner as well after removing the old drivers, always helps.
just done it removed drivers with driver sweeper and driver cleaner after that installed 180.48 set restarted loaded up tmn and crashed 5s after loading the track :( ill run memtest over the night and see if i get any errors :)
tried 178.24 set still the same :/ if memtest wont find any errors ill just repair windows xp maybe some files are corrupted.. :)
Heh, I have the following if he realllllllly wants to :p
169.21, 169.28, 169.44, 177.79, 178.24......:rolleyes:
so tried everyram stick still the same i read some things about this error and some people saying it could be related to hdd?
wouldnt think so. i would think more along the lines of repairing the files in xp and seeing what that does. but like you said, run memtest 1st
fixed it :) been sitting here for 4hrs+ reading google after that debuging dump files and finaly got what was cousing it :( it's asus splendid video driver have no idea how it does it but after removing it and renaiming dll from system32 directory atkdisp.dll problem was solved :)
Asus video driver? Why are you using that anyway? :p
What card you got?
asus 8800gt and i do have nvidia drivers it's not the actual video driver for games it's some kind of codec and real time overclocking utility :o
Ah ok, that makes sense.
I have an annoying ai booster thing on my motherboard.....Which requires an Asus driver, luckily it hasn't caused any issues yet.
